Website: HandBrake
We perform a simple encoding test using the freely available HandBrake software, which converts a 60-second, 400MB, 4K, MKV video sample to a high quality, 1080p, MP4 file using the available presets. Our results show strong scaling with increasing threads, which is indicative of high-performance video editing suites, albeit without any GPU acceleration.
Website: Futuremark
This workload involves making a series of adjustments to a set of RAW and JPG photographs using ImageMagik - an open-source image processing library - to apply a range of filters with a live preview. The images are then saved in JPG and PNG formats.
Website: Hamstersoft
Hamster Zip Archiver is a free and popular file compression tool which supports CPU multithreading. We use a 1.5GB folder which includes large video files plus hundreds of photos and documents in the normal compression mode and record the time it takes to complete the task.
Website: Maxon
Cinebench uses Maxon's Cinema 4D engine to render a photo-realistic scene of some shiny balls and weird things (we miss the motorbike). The scene is highly complex, with reflections, ambient occlusion, and procedural shaders, so it gives a CPU a tough workout.
As Cinema 4D is a real-world application - used on films such as Spider-Man and Star Wars - Cinebench can be viewed as a real-world benchmark.
Website: POV-ray
The Persistence of Vision Raytracer is a high-quality, free ray tracing program for creating three-dimensional graphics, which generates images from a text-based scene description and is available for a variety of computer platforms. We use the all-CPU built-in benchmark, which completes a timed task, and we record the time it takes for each CPU to complete it.October 14 2021 | 15:04
