Lavalys Everest Memory Performance
Website: Lavalys
        Asus M3A32-MVP Deluxe
        Asus CrossHair II
        Gigabyte GA-MA790GP-DS4H
        Foxconn A79A-S
          2000
          3000
          4000
          5000
          6000
          7000
          8000
          9000
    MB/s (higher is better)
Read (MB/s)
Write (MB/s)
Copy (MB/s)
        Asus CrossHair II
        Foxconn A79A-S
Nanoseconds (lower is better)
Even though we set the memory speed identical to the other boards tested at 1,066MHz, 5-5-5-15-2tRFC-2T, the Foxconn is slightly slower in read and copy speeds and has a fractionally lower latency than the Asus 790FX with SB600 and Asus CrossHair II with Nvidia's nForce 780a SLI MCP. Neither is a huge difference in synthetic bandwidth scores, but it's something that can often pass itself down into real-world scenarios.
SiSoftware Sandra Lite XII.2008.SP2c (14.24)
Website: Sisoftware
        Asus CrossHair II
        Foxconn A79A-S
            8870.2
            8789.8
            8634.5
            8631.5
          2000
          3000
          4000
          5000
          6000
          7000
          8000
          9000
        Foxconn A79A-S
        Asus CrossHair II
Sisoft Sandra is somewhat less forgiving and puts the Foxconn A79A-S at the bottom of the table, 200MB/s slower than the Asus 790FX with SB600.  Its latency, on the other hand, is only slightly higher than that of the Asus, but above both the other boards with integrated graphics chipsets.
