Intel NUC D33217CK Review
Written by Antony Leather
March 25, 2013 | 07:53
Tags: #core-i3 #embedded #intel-nuc #low-power #mini-itx #sff
Companies: #intel
Intel NUC D33217CK Left 4 Dead 2 Performance
Developer: Valve Software
From our Left 4 Dead 2 review:
'Not only does Left 4 Dead 2 provide a chance to test your skills against a whole host of new enemies and using a slew of new equipments, it also lets you play with the new modes and maps created by Valve – and the worst levels created by Valve are still twice as good as the best created by amateur map-makers.'
Left 4 Dead 2
1,280 x 720, 0x AA, 16x AF, high settings
  • AMD A10-5800K (2,133MHz DDR3)
  • AMD A10-5800K (4.4GHz)
  • AMD A10-5800K
  • AMD A8-3870K (3.6GHz)
  • AMD A8-3850 (3.04GHz)
  • AMD A8-3870K (3.GHz)
  • AMD A8-3850 (2.9GHz)
  • Intel NUC D33217CK
  • Intel Core i3-2100 (3.1GHz)
    • 78
    • 113
    • 75
    • 105
    • 73
    • 102
    • 63
    • 88
    • 60
    • 80
    • 56
    • 79
    • 54
    • 76
    • 25
    • 47
    • 13
    • 22
50
75
100
125
Frames per second, higher is better
  • Minimum
  • Average
Left 4 Dead 2
1,680 x 1,050, 0x AA, 16x AF, high settings
  • AMD A10-5800K
    • 57
    • 72
    • 53
    • 68
    • 42
    • 58
    • 38
    • 55
    • 35
    • 50
    • 33
    • 48
    • 20
    • 34
    • 9
    • 15
20
30
40
50
60
70
80
  • Minimum
  • Average
SATA Performance
Website: ATTO Disk Benchmark
We tested the SATA and performance with an OCZ Vertex 3 240GB, as this is the fastest SSD we've ever tested, and it can test the maximum speed of SATA 3Gbps and SATA 6Gbps ports.
We use ATTO Disk Benchmark, and take the read and write speeds for 1,024KB data chunks.
SATA 6Gbps Performance
ATTO Disk Benchmark
  • ASRock Fatal1ty Professional-M (Intel Z77)
  • Asus Maximus V Gene (Intel Z77)
  • Intel DZ77GA-70K (Intel Z77)
  • MSI Z77A-G43
  • Gigabyte GA-Z77-UD5H (Intel Z77)
  • Intel NUC D33217CK (Intel SSD 525 Series 120GB)
  • Asus Maximus V Gene (ASMedia)
  • ASRock Fatal1ty Professional-M (ASMedia)
  • Gigabyte GA-Z77-UD5H (Marvell 88SE9172)
  • Intel DZ77GA-70K (Marvell 88SE9172)
    • 542
    • 547
    • 542
    • 509
    • 542
    • 507
    • 542
    • 507
    • 541
    • 507
    • 532
    • 494
    • 395
    • 376
    • 391
    • 372
    • 365
    • 239
    • 358
    • 190
200
300
400
500
600
MB/sec, higher is better
  • Read
  • Write
Read our performance analysis.
null
