Media Benchmarks
Download from: bit-tech.net
We have developed our own suite of benchmarks using real-world and open source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while a HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
GIMP Image Editing
Website: GNU Image Manipulation Program (GIMP)
Far from being some kind of pr0n-filtering tool, Gimp is an open source image editing application - Gimp is an acronym of GNU Image Manipulation Program. Our test simulates how well a PC can manipulate a collection of large digital photos, and to achieve a low time requires a PC with a powerful CPU, plenty of quick memory and efficient hard disk drive access.
Asus Crosshair IV Formula
MSI 785GM-E65
MSI 890GXM-G65 (BIOS 1.0)
Asus M4A89GTD Pro/USB
MSI 890FXA-GD70
Score (points), higher is better.
Handbrake H.264 Encoding
Website: HandBrake
We use the open-source, GPL-licensed, multi-platform, multi-threaded video encoder Handbrake to encode a HD video using the H.264 codec. This primarily tests multi-threaded CPU and memory subsystem performance.
MSI 785GM-E65
MSI 890FXA-GD70
500
750
1000
1250
1500
1750
Multitasking Performance
Website: MPC-HC
Website: 7-Zip
Multi-tasking is a phrase that we're all familiar with, because most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using mplayer, making it a demanding test for any PC.
MSI 890FXA-GD70
MSI 785GM-E65
MSI 890GXM-G65
Overall
The overall score is an unweighted mean average of the scores of the three individual tests.
MSI 785GM-E65
MSI 890FXA-GD70
500
750
1000
1250
1500
Read
how to overclock the MSI 890FXA-GD70, or our
Performance Analysis.
