Battlefield 4
Publisher: EA
From our
Battlefield 4 review:
From the start to the end of the campaign you literally have no idea who’s who, why they do or don’t like each other and even what part you play in the whole thing – the latter point not being helped by the fact you’re mute throughout the whole game. You just meander from mission to mission and get on with the task set before you.
Still: who cares, right? Battlefield has long been about its multiplayer, and sure enough here, again the game truly shines. Largely it’s a continuation of what came before but there are enough extras that it feels, if not totally new, different enough to learn all over again.'
With its demanding Frostbite 3 engine, Battlefield 4 is a tough challenge for any GPU. We run the game at its highest 'Ultra' settings with motion blur at 50 percent and the resolution scale at 100 percent. We also manually disable MSAA. We run a 60 second benchmark on the game's sixth campaign level, Tashgar, during the on rails section at the level's start, and begin the recording as soon as the subtitle for the first line of dialogue appears on screen.'
        Cyberpower Infinity X55 Pro GT
        MSI GTX 970 Gaming 4G 4GB
        AMD Radeon R9 290 4GB
        AMD Radeon R9 280 3GB
        PC Specialist Apollo 703
        AMD Radeon R9 270X 2GB
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
        Overclockers UK Infin8 Nebula
        Utopia Pandora
Frames Per Second
Crysis 3
Publisher: EA
Unfortunately our usual Crysis 3 test refused to run on the system, most likely due to issues with Windows 10. We're currently investigating the issue and will include results if possible at a later date.
