Unigine Valley 1.0 Benchmark
Publisher: Unigine
Unigine's free Valley 1.0 benchmarking tool works well as a graphics benchmark as it is GPU limited and is thus incredibly taxing on the GPU whilst placing the CPU under very little stress. Unigine's scoring system is effectively linear: a card with 2,000 points is considered twice as fast as one with 1,000 points, and half as fast as one with 4,000 points.
Overclockers UK Infin8 Nebula
DinoPC Troodon
Fresh Tech Solutions Ultimate Collection 6700K
Utopia Pandora
Overclockers UK Titan Wave
MSI GTX 970 Gaming 4G
PC Specialist Vitrum
Cyberpower Infinity X55 Pro GT
Fresh Tech Solutions 6600K Falcon R
AMD Radeon R9 290 4GB
PC Specialist Apollo 703
Dino PC GSX
AMD Radeon R9 280 3GB
CCL Elite Strix 100
AMD Radeon R9 270X 2GB
2000
3000
4000
5000
6000
7000
Score (higher is beter)
PCMark 8 Video Editing
Video Editing V2 Part 2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
DinoPC Troodon
Dino PC GSX
Utopia Pandora
Intel Core i7-4790K (4GHz/4.8GHz)
Intel Core i7-5930K (3.5GHz/4.55GHz)
CCL Elite Strix 100
AMD FX-8350 (4GHz/4.6GHz)
200
300
400
500
600
Seconds, lower is better
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Dino PC GSX
DinoPC Troodon
Utopia Pandora
CCL Elite Strix 100
