1200W PSU Roundup 2014
Written by bit-tech Staff
September 15, 2014 | 09:17
Tags: #1200w #power-supply #psu #super-flower
Companies: #antec #be-quiet #bit-tech #chieftec #cooler-master #corsair #evga #seasonic
Efficiency
Each PSU's efficiency is calculated by dividing the power it outputs by the power it uses to do so. While the average efficiency of all the load tests is what's considered for the scoring, the results and rankings of the individual load intervals are also displayed below (yay, graphs!).
Average Efficiency
Mean efficiency across load tests >100W
  • Seasonic Platinum Series 1200W
  • EVGA SuperNova P2 1200W
  • Corsair Professional Series AX1200i
  • Chieftec Navitas 1250W
  • Antec HCP-1300 Platinum
  • Super Flower Leadex Platinum 1200W
  • Cooler Master V1200 Platinum
  • Be Quiet! Dark Power Pro 10 1200W
  • 91.60
  • 91.29
  • 91.04
  • 90.89
  • 90.83
  • 90.79
  • 90.70
  • 89.81
50
75
100
Percentage (higher is better)
Efficiency
200W load test
  • 89.81
  • 88.87
  • 88.70
  • 88.22
  • 88.12
  • 87.70
  • 86.30
  • 85.77
20
30
40
50
60
70
80
90
Efficiency
300W load test
  • 90.93
  • 90.90
  • 90.56
  • 90.51
  • 89.67
  • 89.63
  • 88.90
  • 88.80
50
75
100
Efficiency
400W load test
  • 91.64
  • 91.43
  • 91.42
  • 91.37
  • 91.31
  • 90.72
  • 90.59
  • 89.96
50
75
100
Efficiency
500W load test
  • 92.13
  • 92.09
  • 91.73
  • 91.72
  • 91.51
  • 91.29
  • 91.21
  • 90.68
50
75
100
Efficiency
600W load test
  • 92.17
  • 92.10
  • 92.02
  • 91.58
  • 91.50
  • 91.41
  • 91.12
  • 90.93
50
75
100
Efficiency
700W load test
  • 92.46
  • 91.99
  • 91.78
  • 91.76
  • 91.69
  • 91.54
  • 91.11
  • 90.70
50
75
100
Efficiency
800W load test
  • 92.38
  • 91.82
  • 91.60
  • 91.59
  • 91.56
  • 91.35
  • 91.27
  • 90.30
50
75
100
Efficiency
900W load test
  • 92.30
  • 91.76
  • 91.52
  • 91.46
  • 91.37
  • 91.36
  • 91.28
  • 90.59
50
75
100
Efficiency
1000W load test
  • 92.44
  • 91.53
  • 91.40
  • 91.19
  • 91.18
  • 90.95
  • 90.94
  • 90.30
50
75
100
Efficiency
1100W load test
  • 91.81
  • 91.16
  • 91.10
  • 91.10
  • 91.09
  • 90.90
  • 90.83
  • 89.89
50
75
100
Efficiency
1200W load test
  • 91.42
  • 91.21
  • 90.86
  • 90.76
  • 90.67
  • 90.54
  • 90.23
  • 89.51
50
75
100
Efficiency
1300W load test
  • 90.88
  • 0.00
  • 0.00
  • 0.00
  • 0.00
  • 0.00
  • 0.00
  • 0.00
50
75
100
