Fractal Design Integra M 650W Review
Written by bit-tech Staff
March 13, 2015 | 14:11
Tags: #80-plus-bronze #modular #psu
Companies: #fractal-design
Manufacturer: Fractal Design
UK price (as reviewed):
£62.00 (inc VAT)
US price (as reviewed): Currently unavailable
Fractal Design is forging ahead by releasing products related to its core competency of producing decent chassis at affordable prices. In particular, Fractal has renewed focus on power supply units (PSUs) by adding more capacities and catering for a wider gamut of users.
The Integra M, available in 450W, 550W, 650W and 750W capacities, is a case in point, designed for budget small-form-factor systems and outfitted with semi-modular cabling.
*Fractal Design Integra M 650W Review Fractal Design Integra M 650W Review *Fractal Design Integra M 650W Review Fractal Design Integra M 650W Review
At 140mm deep, the 80 PLUS Bronze supplies are kept deliberately short to facilitate easy installation into smaller chassis. Equipped with a temperature-controlled, sleeve-bearing 120mm fan presented in usual Fractal white, helping colour co-ordinate PCs, overall build quality is predictably good - the soft-feel exterior belies the £60 price tag.
It's refreshing to find modular cabling present on budget supplies, and it is particularly useful if working within confined spaces. The 650W model, for example, has four connections in addition to the captive cabling which consists of a 24-pin ATX cable, 8-pin ATX12V cable and dual 6+2-pin PCI-E. The remainder are modular and are comprised thus:
CablesLength, plugs
Main (24-pin)51cm x1 (fixed)
ATX/EPS (8-pin)70cm x1 (fixed)
PCI-E (6+2-pin)50-60cm x2 (fixed)
52-62cm x2
SATA40-64cm x4
65-89cm x3
Molex40-52cm x2
FloppyNone
Sensibly, all the additional cables, which are nicely flat and easy to manage through motherboard holes, can be used at once, and Fractal ensures easy connection of the 8-pin CPU cable by making it 70cm long.
Amps/watts and voltage3.3V5V12V1-12V+5VSB
Rail amps20A20A54A0.5A2.5A
Maximum rating100W648W6W12.5W
Maximum continuous rating650W @ 40°C ambient
The 80 PLUS Bronze rating means efficiency isn't as sharp as dearer supplies yet Fractal guarantees the total 650W output at a decent ambient temperature of 40°C, or up to 80 percent of the capacity at a toastier 50°C. Practically all the capacity can be shunted down the single 12V rail too. Increased heat is a by-product of using 80 PLUS Bronze-rated supplies which aren't as efficient as pricier models, so it's good to see a reasonable ambient rating.
Inside, the unit is made on behalf of Fractal by Taiwanese manufacturer ATNG, and this should come as no surprise as other supplies in the line-up, such as the Newton R2/R3 and Tesla, also use ATNG's technology.
Budget constraints do reveal themselves through the use of cheaper Teapo capacitors, rated at 85°C, for both the primary and secondary filtering. Soldering quality is reasonable and, just like the outside, build quality remains good.
