SilverStone Strider Platinum 750W Review
November 17, 2015 | 12:46
Tags: #80-plus-platinum #power-supply #psu
Companies: #silverstone
+12V Rail Tests
For these tests, we take a reading of the voltage output of each PSU's 12V rail (or rails, if it uses a multi-rail design). This is done at three load levels: low, medium and high, which vary based on the wattage of PSU being tested. We are looking for results as close to 12V as possible. Higher loads are more likely to highlight any instabilities. Any output that falls outside of Intel's specifications is considered a fail and highlighted in red.
+12V Rail Output - Low Load (200W)
ATX spec limit: 11.4V - 12.6V
  • EVGA SuperNOVA 850 P2 850W
  • SilverStone SX600-G 600W
  • SilverStone ST75F-PT 750W
  • Cooler Master V550 550W
  • Antec EDGE 650W
  • Fractal Design Integra M 650W
    • 12.07
    • 12.12
    • 12.15
    • 12.15
    • 12.16
    • 12.20
8
10.5
13
Volts (blue = pass; red = fail)
  • +12V rail output
+12V Rail Output - Medium Load (400W)
  • Antec EDGE 650W
    • 11.99
    • 12.02
    • 12.04
    • 12.06
    • 12.09
    • 12.10
8
10.5
13
  • +12V rail output
+12V Rail Output - Max Load
  • Antec EDGE 650W
    • 11.82
    • 11.85
    • 11.88
    • 11.90
    • 11.98
    • 12.02
8
10.5
13
  • +12V rail output
