SilverStone Strider Platinum 750W Review
November 17, 2015 | 12:46
Tags: #80-plus-platinum #power-supply #psu
Companies: #silverstone
Efficiency
Each PSU's efficiency is calculated by dividing the power it outputs by the power it uses to do so. Starting at 100W load, we test in 100W load increments up to an including the maximum rated wattage. While the average efficiency of all the load tests is what's considered for the scoring, the results and rankings of the individual load intervals are also displayed below.
Average Efficiency
Mean efficiency across load tests 100W+
  • EVGA SuperNOVA 850 P2 850W
  • SilverStone ST75F-PT 750W
  • Antec EDGE 650W
  • SilverStone SX600-G 600W
  • Cooler Master V550 550W
  • Fractal Design Integra M 650W
    • 92.70
    • 92.02
    • 89.99
    • 89.86
    • 89.67
    • 84.95
50
75
100
Percentage (higher is better)
  • Efficiency
Efficiency
200W load test
  • Antec EDGE 650W
    • 91.33
    • 91.06
    • 90.60
    • 90.42
    • 90.42
    • 85.90
50
75
100
  • Efficiency
Efficiency
300W load test
  • Antec EDGE 650W
    • 92.65
    • 92.06
    • 91.32
    • 91.24
    • 90.82
    • 86.28
50
75
100
  • Efficiency
Efficiency
400W load test
  • Antec EDGE 650W
    • 94.36
    • 94.15
    • 91.10
    • 91.04
    • 90.55
    • 86.07
50
75
100
  • Efficiency
Efficiency
600W load test
  • Antec EDGE 650W
    • 94.02
    • 93.40
    • 89.96
    • 89.35
    • 84.11
50
75
100
  • Efficiency
Efficiency
Max. load test
  • Antec EDGE 650W
    • 91.13
    • 90.07
    • 89.51
    • 89.38
    • 89.35
    • 83.98
50
75
100
  • Efficiency
Posted by Hustler - Tue Nov 17 2015 13:17
This seems an odd choice of priorities.
750w is enough to power anything upto a 980 SLI system, yet you can't fit two GPU's in any (proper) small form factor case, but there are cheaper PSU's that can power up to a single 980Ti and still fit in such a system..such as their own SFX 600w units or smaller gold rated EVGA units.
..and if you go for one of the larger small form factor cases that can take two GPU's such as 980Ti's, you'll need something closer to 900w to power two of them.
null
