Cooling Performance
Our mini-ITX test kit includes:
- CPU: Intel Core i5-2500K overclocked to 4.3GHz using a vcore of 1.3V.
- Graphics card: GeForce GTX 570 1.3GB
- Motherboard: Asus P8Z77-I Deluxe
- RAM: 4GB Kingston DDR3 1600MHz memory
- PSU: Enermax Eco 82+ 620W PSU
- CPU cooler: Zalman CNPS 8900 low-profile cooler
While some cases can house larger coolers, for the results to be comparable, we needed to pick a cooler that was going to fit in as many cases as possible. We therefore opted for a low-profile cooler. This will give a good idea of how well the case is able to remove heat from the system - our primary concern in case testing - although you can probably expect to achieve better results by using a larger cooler if the case in question supports it.
The graphics card fan was locked at 70 per cent speed and the system was loaded using Prime95 and Unigine's Heaven benchmark. We used Realtemp and GPU-Z to monitor the temperatures, taking the maximum values when the readings had plateaued.
SilverStone Raven RVZ01
Silverstone Sugo SG08 (max speed)
BitFenix Prodigy
Silverstone Sugo SG08 (min speed)
Silverstone FT03-Mini
Fractal Design Node 304 (max speed)
Cooler Master Elite 130 Advanced
Lian Li PC-TU200
Thermaltake Core X1
Corsair Obsidian 250D
Lian Li PC-V360 (micro-ATX)
Lian Li PC-Q28
In-Win 901 (Zalman ZM-F2 92mm + Noctua NF-F12 120mm)
Lian Li PC-V358 (micro-ATX)
EVGA Hadron Air
BitFenix Phenom
Corsair Carbide Series Air 240 (micro-ATX)
Cooler Master Elite 120 Advanced
Xigmatek Nebula C
Antec ISK600
Raijintek Metis (w/ Asus GTX 970 Mini) (fan reversed)
Xigmatek Octans
Fractal Design Node 304 (min speed)
BitFenix Pandora (micro-ATX)
Parvum Systems X1.0 (Max speed)
Corsair Graphite 380T (max speed)
Parvum Systems X1.0 (7V)
Parvum Systems X1.0 (5V)
Corsair Graphite 380T (min speed)
SilverStone Precision PS09 (micro-ATX)
In-Win 901 (no fans)
20
30
40
50
60
70
80
°C, lower is better
Parvum Systems X1.0
Xigmatek Octans
BitFenix Prodigy
Xigmatek Nebula C
Thermaltake Core X1
Corsair Carbide Air 240 (micro-ATX)
Antec ISK600
EVGA Hadron Air
BitFenix Phenom
Lian Li PC-Q28
Lian Li PC-TU200
20
30
40
50
60
70
80
°C, lower is better
