PCMark 8 Video Editing
Video Editing Part 2 V2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom-built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
        Intel Core i5-7600K (5.1GHz)
        Intel Core i7-7700K (5GHz)
        Intel Core i7-7700K
        Intel Core i5-7600K
        Intel Core i7-6850K (4.2GHz)
        Intel Core i7-6900K (4.2GHz)
        AMD Ryzen 7 1800X (4GHz)
        Intel Core i7-6850K
        AMD Ryzen 7 1800X
        Intel Core i7-6900K
Seconds (lower is better)
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library - to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
        Intel Core i7-6850K (4.4GHz)
        Intel Core i7-7700K
        Intel Core i7-6850K
        Intel Core i7-6850K
        Intel Core i7-6900K
        AMD Ryzen 7 1800X
        Intel Core i5-7600K
HandBrake Video Transcode
We've added HandBrake to our list of media creation tests, as PCMark 8's video encoding test isn't able to make use of more than two threads and as such doesn't give a true representation of video encoding/editing workloads and performance. As this task is a key reason for opting for a powerful system, we've added a simple encoding test using the freely available HandBrake software, which converts a 60-second, 400MB, 4K, MKV video sample to a high quality 1080p MP4 file using the available presets. Our results show much better scaling with increasing threads, which is more indicative of high-performance video editing suites, albeit without any GPU acceleration.
        Intel Core i7-6900K
        AMD Ryzen 7 1800X
        Intel Core i7-6850K
CPU-Z
Publisher Cpuid.com
The popular tool for identifying key system information such as realtime CPU frequency, voltage, BIOS version memory speed, and a whole load of other figures, also includes a built-in benchmark tool. This assesses both single and multi-threaded performance in an extremely quick test directly within the usual interface. It also offers a stress test and the ability to limit the number of threads being benchmarked. We use the default settings and obtain both single and multi-threaded results.
        AMD Ryzen 7 1800X (4.05GHz)
        AMD Ryzen 7 1800X
        Intel Core i7-6900K
        Intel Core i7-6850K
Score (higher is better)
Multi-threaded
Single-threaded
