Power Consumption
For all of the overclocked performance tests, we disable all power-saving technology in order to give us a consistent set of results, and also best-case performance numbers - even though technologies such as Intel's SpeedStep might only take microseconds to kick in, that can make a difference in some tests.
However, for the stock speed results and power consumption tests, we re-enable everything in order to get a real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below are of total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve.
We use Prime95's small FFTs test to put the CPU under 100 percent load, while idle power results are taken with the PC sitting at a Windows Aero-enabled desktop.
Intel Core i7-7700K
Intel Core i5-7600K
Intel Core i7-7700K (5GHz)
AMD Ryzen 7 1800X
Intel Core i5-7600K (5.1GHz)
AMD Ryzen 7 1800X (4GHz)
Intel Core i7-6850K
Intel Core i7-6900K
Intel Core i7-6850K (4.2GHz)
Intel Core i7-6900K (4.2GHz)
Watts (lower is better)
Intel Core i5-7600K
Intel Core i7-7700K
Intel Core i7-6850K
Intel Core i7-6900K
AMD Ryzen 7 1800X
