Gigabyte Aorus AX370-Gaming 5 Review
Written by Antony Leather
March 22, 2017 | 15:06
Tags: #am4 #am4-motherboard #best-ryzen-motherboard #ryzen #x370 #x370-motherbiard
Companies: #amd #gigabyte
PCMark 8 Photo Editing V2
Gigabyte Aorus AX370-Gaming 5 Review Gigabyte Aorus AX370-Gaming 5 - Video Editing and Photo Editing
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library - to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
  • Gigabyte Aorus AX370-Gaming 5 (3.6GHz/4.05GHz)
  • Asus Crosshair VI Hero (3.6GHz/4.05GHz)
    • 28
    • 24
    • 30
    • 23
10
15
20
25
30
Seconds (lower is better)
  • Stock
  • Overclocked
HandBrake Video Transcode
We've added HandBrake to our list of media creation tests, as PCMark 8's video encoding test isn't able to make use of more than two threads and as such doesn't give a true representation of video encoding/editing workloads and performance. As this task is a key reason for opting for a powerful system, we've added a simple encoding test using the freely available HandBrake software, which converts a 60-second, 400MB, 4K, MKV video sample to a high quality 1080p MP4 file using the available presets. Our results show much better scaling with increasing threads, which is more indicative of high-performance video editing suites, albeit without any GPU acceleration.
HandBrake Video Transcoding
4K MKV to high quality 1080p MP4 encode
  • Gigabyte Aorus AX370-Gaming 5 (3.6GHz/4.025GHz)
    • 92
    • 79
    • 99
    • 75
50
75
100
Time (Lower is better)
  • Stock
  • Overclocked
