Be Quiet! Pure Power 10 CM 500W Review
January 31, 2017 | 11:58
Tags: #power-supply #psu
Companies: #be-quiet
Efficiency
Each PSU's efficiency is calculated by dividing the power it outputs by the power it uses to do so. Starting at 100W load, we test in 100W load increments up to an including the maximum rated wattage. While the average efficiency of all the load tests is what's considered for the scoring, the results and rankings of the individual load intervals are also displayed below.
Average Efficiency
Mean efficiency across load tests 100W+
  • EVGA SuperNOVA 850 P2 850W
  • SilverStone ST75F-PT 750W
  • Antec EDGE 650W
  • SilverStone SX600-G 600W
  • Cooler Master V550 550W
  • Be Quiet! Pure Power 10 CM 500W
  • Be Quiet! Pure Power 9 CM 600W
  • Fractal Design Integra M 650W
    • 92.70
    • 92.02
    • 89.99
    • 89.86
    • 89.67
    • 87.63
    • 86.44
    • 84.95
50
75
100
Percentage (higher is better)
  • Efficiency
Efficiency
200W load test
  • Antec EDGE 650W
    • 91.33
    • 91.06
    • 90.60
    • 90.42
    • 90.42
    • 87.10
    • 86.30
    • 85.90
50
75
100
  • Efficiency
Efficiency
300W load test
  • Antec EDGE 650W
    • 92.65
    • 92.06
    • 91.32
    • 91.24
    • 90.82
    • 89.02
    • 86.82
    • 86.28
50
75
100
  • Efficiency
Efficiency
400W load test
  • Antec EDGE 650W
    • 94.36
    • 94.15
    • 91.10
    • 91.04
    • 90.55
    • 88.03
    • 87.04
    • 86.07
50
75
100
  • Efficiency
Efficiency
Max. load test
  • Antec EDGE 650W
    • 91.13
    • 90.07
    • 89.51
    • 89.38
    • 89.35
    • 86.38
    • 85.61
    • 83.98
50
75
100
  • Efficiency
Aquaceras Part 10 - Making Custom DDC Heatsinks
February 26 2021 | 22:15
